Reading plugs
540spdwagn
10:51 AM
N.W. Arkansas
What's you guys procedure on shutting the car down after the finish line so you can get a good read on the plugs? Trans is reverse pattern 727.
Click the ignition off while at WOT,then put it "N" asap and you should be fine.
Th
They make a transmission with a "clean neutral" and a PPG shifter to accomdate it.
The pattern is P R N 1 2 3 N
There is a second Neutral "after" high gear, so you can shift into neutral without going thru 2nd and 1st, which, of course, you cant do after going thru the traps.
Th
I always wondered what "clean neutral" meant !
