New wheels and tires for the X
dan juhasz
12:17 AM
Whiting NJ
I'm going to treat the GTX to a new set of magnums and redline tires. It's a stock car all around so I'm interested in maintaining a stock appearance. Having said that I do have a few questions and would appreciate feedback.
Should I stay with 14 inch or move up to a 15 inch wheel and tire.
The correct magnum for a 67 is no trim ring, correct?
I was going to buy the new Firestone Wide Oval Radial Redline, instead of the BFG or the other Coker branded tires. Good choice?
I was going with a FR70 size tire. Would that be the equivalent of the factory size?
Thanks in advance
Dan
If you are not doing exactly what originally came on the car then does the trim rings even matter?
15's fill the gaps better, mainly referring to the front.....
My charger in the avatar has 15" steelies with f70 goodyears....originally was 14" steelies
Basically, if it was a hemi car that would be stock sizes...
As far as the trim rings the question was more looks than concourse. Which is a better look.
Thanks in advance
Dan
I went with 15 Magnums on my GTX. They do fill the wheel well a bit better. Their taller size will slightly raise your effective rear gearing however if that matters to you. Probably won't notice the difference. I think originals were 7.75 - 14 and the FR70 would be a little wider in cross section. A 75 series tire is probably the closest you will get in a modern tire to the originals unless you buy repro tires from Coker or somewhere. I'm about to replace my 215/75-15 redlines and I will probably stick with that size. I believe I installed 7 inch wide Magnums however and if doing again I would probably stick with 15 x 6 inch for a fairly stock look. The 7 inch wide ones with the bigger tires are very tight to get into the rear wheel wells when removing or installing.
Thanks for all the info, your car is stunning in white.
Definitely looks better in pictures.
Thanks in advance
Dan
Thanks in advance
Dan
Magnum 500s are chrome. The road wheels have the trim ring. None of the 67 GTXs came with the road wheels
Dan,
Please post tire size, wheel size and wheel offset when you get it all sorted out. I have a '66 belvedere and '66 charger and am curious as to what will fit.
I once had a '67 coronet with 15x7 torque thurst rims(not sure of tire size) and they rubbed the inner fender if I didn't inflate my rear air shocks. Which inflating the air shocks caused the drive shaft angle to change and that created a vibration at speed.
I went with the 15 by 7 magnums and 205-60's on the front and 235-60's on the rear. I have good clearance all around. I may do redlines soon and plan to do the Diamondback redlines since they are a BFG radial TA and I like the look and driving characteristics of the tire. The Diamondback redlines are a shaved white letter tire with the redline added, so the warranty is with Diamondback, not BFG.
I will most likely buy a fifth 7 inch magnum for the spare and five 205 width tires and get rid of the staggered tires so the spare can go on all four corners and I can rotate the tires if I want. I really have no rear traction issues with the 235's, and automatic and 3.23 gearing. A little smaller rear tire would probably be fine. The 7 inch wheel does not fit the trunk spare tire well as it pushes up the spare tire well cover. I may also go up to a 65 or 70 sidewall on the redlines.
Recently installed some Cooper 235/60R14's mounted on Mag 500's on the '66 Belvedere and they don't rub.
Dan,
Please post tire size, wheel size and wheel offset when you get it all sorted out. .
I'ii see what I can find and post.
Dan,
The Magnums are 15x7 with a 4.25 inch backspace. The tires are Coker 215/75-15.
Mine are pretty tight getting on in the rear. I have to jack the rear up and let the axle hang all the way down - and still I have to fight them. I think the 15x6 Magnums would be better. Or, I think 15x7 Magnums can be had with a backspace up to 5 inch. The 15x6 that Coker sells has a 4 inch backspace.
The original 7.75 - 14 tires on the 67 GTX should have had a 26.3 inch diameter. This is equivalent to a 75 sidewall on a 14 inch wheel. When you go to 15 inch wheels and a 75 sidewall, your tire diameter increases to over 27 inches, your speedometer reads low and your car goes faster at the same RPM. If you want to keep the speedometer accurate, you need to drop to a 70 sidewall if you go to 15 inch wheels. This maintains the 26.3 tire diameter of the original factory tire.
"Filling up the wheel well" can be taken two different ways. The 15 inch wheels do visually help since there is more actual "wheel" in the wheel well and a 14 inch wheel in the days of 15-20 inches being normal do look rather small. A 70 series tire will not fill up the gap between the top of the wheel and body in the front, but will maintain the original diameter and make the rears somewhat easier to get on and off. If you ever used the old bumper jack, you have to jack the car ridiculously high, but the rear axle drops plenty enough for wheel removal. The old bumper jack also has a tendency to bend the bumper. This is not the case if you use a floor jack on the frame in front of the rear wheel and why the wheels are so hard to remove, particularly in a 67 with tight wheel wells and if the rear tires oversized in width and diameter.
I think I will go with 205-70 15's all around next time, with Magnum 500 wheels and redlines including the spare tire. This is closer to original tire width and height, I can rotate the tires like the old days without staggered tires, and the car will look good and just the same with the spare on in the unlikely event of a flat.
What will happen if I actually have to use my bumper jack since it is now all powder coated is a worry for when that time comes. Some will undoubtedly crack and fall off. I am not going to carry a floor jack around in the trunk, even though it is bigger than the typical "tiny house".
Is the 7.75 x 14 equivalent to a 195 75 14?
