Still chasing little things.
Took it over to have the alignment done and the guy mentioned the strut rod bushings looked worn. The car had been pulling left during braking and they looked a bit crushed so I replaced them with urethane bushings. After I had the pass side loose I saw that the lca bushing inner sleeve had pulled out about 3/16" from the rubber so I replaced it while I was in there.  Pull was still there so I re bled the pass front brake again and adjusted the brakes a little tighter and I think that did the trick.
I have also been chasing a thunk clunk in the trunk. Pretty loud in the cab and I can replicate it by bouncing the rear end. Removed everything and still there. Re adjusted the exhaust, secured any and all lines away from the body...still there. Soooo I started pulling the new KYB gasadjust shocks....sound went away. Put on an old, used set and no more sound. I can't say how much crap I have bought that goes bad or is bad out of the box.
