munger77
B Body Mechanical, electrical gremlins; impossible to reach bolts; what stumped you and what was the solution?
This is not a mopar problem but it's a problem that I had to solve.My daughter have a 2011 chevy cruze that kept running hot and I tried everything that I could think of.took it to the dealer and they had it 7 days and they couldn't find the problem.during the time her car was down she used my wife's car to go to school which was a large car and she is small.I spent money on everything I thought could be wrong with it after the dealer could not fix it.the car would start up and it would start blowing water back to the coolant jug and run up to 230 in less than2B Body Mechanical, electrical gremlins; impossible to reach bolts; what stumped you and what was the solution?
Probably one of the weirdest things I had to deal with was not knowing you had to adjust the power steering spool valve. Freaked me out when I first started the car and the steering wheel flew to the left all on its own. Lol
The difference a year will make on a body style that never changed.1968 AMC Rebel station wagons
Had one come in the shop for a flywheel ring gear. Removed driveshaft, torque converter bolts, transmission, flywheel. Heated the gear ring to remove from flywheel, heated new ring and dropped it on the flywheel. Replaced everything including a new starter bendix gear. Good to go.
Exactly one week later, (I thought it was the same car), pulls into the shop with the same problem, stripped flywheel ring. Well it was identical to the one I did the week before, even the color. The boss quotes the customer the same cost as the one before and gets the go-ahead.
Get the car up on stands, craw under it, and I couldn't believe what I was seeing. It had coil springs instead of leaves. The driveshaft was an enclosed one bolted to the rear and to the trans. The whole rear end/driveshaft assembly had to be dropped out from under the car and rolled out of the way in order to get at the trans. Go to drop the trans and the flywheel is welded to the torque converter. The ring gear is even welded to the flywheel. Had to order the whole tc/ring gear/flywheel assembly. Over $400 just for that. (This was mid 70's)
The boss took a big hit on that job and learned that when dealing with AMCs to check what you have before giving a quote. Some jobs you'll never forget.
They were both the same year! Same color, same interior, same wheel covers, same engines, automatics. Really bazaar in the way that it all took place.The difference a year will make on a body style that never changed.
