- 12:33 AM
- Oct 16, 2014
- Salisbury, Vermont
Do you have a dial caliper? Those will tell you all you need to know about the size.How do I tell what mine are?
Yeah you can do that....you can also install a pair of heavier duty front shocks. You might try the shocks first and if you feel they're not enough, then go with the heavier bars. I lowered my 66 Belvedere and installed much better shocks (the old ones were worn out anyways) and it worked for me.Not to hi jack this thread but I have a question to the masters about bars. I am retaining the 383 n my coronet and want to put heavier bars on it to be able to lower the front end and still retain support. I was told this is a way to be able to do that, by putting heavier bars in it? Am I correct in my thinking?
I do.Do you have a dial caliper? Those will tell you all you need to know about the size.
I use a set of dial calipers, or you can use micrometers to get an accurate measurement. Compensate for a heavy coating of paint or whatever.How do I tell what mine are?
Being a machinist, I'm pretty accurate with dial calipers so long as they are not those Shinese onesI use a set of dial calipers, or you can use micrometers to get an accurate measurement. Compensate for a heavy coating of paint or whatever.
Odd numbered bars go on the left, even numbered bars go on the right. I believe the 667, 666 are the last 3 digits of the part number.
