upper ball joint.
ddpsnake
10:45 AM
Belleville Canada
Moog t412 is the right socket to remove the upper ball joint on my 71 salty.Just need to know. Also the moog k772 is the right ball joint.Thanks again.
Moog K772 is the upper ball joint, it fits 1965-1974 SATELLITE cars. Don I used it when I did my complete front end rebuild on my car last year
Don when you go to get an aligment make sure you set the ride height first to what you want. Factory manual alignment specs are no good for radial tires, they only work if you use bias-ply tires. For Radial tires use Camber -.50 to 0 degrees, Caster as much positive as you can get up to 3 degrees and toe in 1/16th to 1/8th inch. This is what I told the aligment shop to do and my car runs down the road straight as an arrow now. You will be limited to what you can do with stock A arm bushings, but if you have the Moog off set A arm bushing you can tweek it a little more.
you can also use the bigger C body tie rod ends that are stronger then the B Body tie rod ends. C Body cars use the 11/16 shank tie rod ends and B Body cars use the 9/16 shank tie rod ends, they bolt right up with no modifications. I did this on my car. You will have to use a C Body tie rod adjusting sleeve. PM if you want more information about the C body tie rod swap, it is worth doing
Great advice Kelly,wear did you get your alignment done.
Charlies work place, the guy that does the aligment work knows what is needed to get them to go down the road straight. Take him the numbers I told you to use and he will fix you up.
sounds like a good idea I'm just about to replace inner and outer tie rod ends with sleeves
send me the p/numbers please . i sent my box out to firm feel and getting to upper a arms at the same time
so I'm going to set it up as you said
I got all the parts from Rock Auto in the States
2 - Moog ES352R Outer tie rod for a (1970 Chrysler New Yorker)
2 - Moog ES355L Inner tie rod for a (1970 Chrysler New Yorker)
Moog doen't make an adjusting sleeve for the tie rod ends (I checked with Moog and they told me this, he didn't say why or he didn't know) so I went with
1 - PROFORGED 10510049 Billet Aluminum Tie Rod Sleeves; Material: Billet Aluminum; Upgraded Billet Aluminum Sleeves For Improved Performance; Sold In Pairs
Front; Length: 7.10; Thread size: 11/16-18 (for a 1970 Chrysler New Yorker)
These parts are a great upgrade if you are going to use big wide tires on the front of your car. I have P235 60/R15 on the front
Don and 67belvedere/225
these 5 parts cost $187.76 CANADIAN (including tax and duty) shipped to my door from Rock Auto in the States.
If I remember right Napa wanted 70+ for just one tie rod. So the cost for 4 tie rods was $280 plus tax here in Canada. I buy all my parts from Rock Auto it's alot cheaper to get them from Rock Auto then from Napa up here. It took less then a week to have them at my door
Your car is salty ? I have never licked mine. Maybe mine is as well.
they are a great upgrade over the stock type sleeves and they are alot stronger to.
So are the UCA bushing the same from your car to my car? if so do you have the part numbers from rock auto.Thanksss.
1965-1972 Satellite. you will need 2 sets
MOOG K7103 Offset Bushing
Front Upper; Optional; Eccentric Bushing; Provides Additional Positive(+) Camber Adjustment
besides the weather b
I'm getting new upper a arms from firm feel
thanks
