MOPARENT
Anyone else having this issue? I got these from Classic Ind to keep that "original look" under the hood, but these things don't grip well at all. The lower rad hose was leaking at the pump so I added a hose clamp to it. The upper was doing fine for a while, but now the hose slides back and forth a 1/2 inch on the rad outlet and looks like its about to blow off! I am using a aluminum rad. Should I emery up the outlet? Or should I just dump the spring clamps altogether?
