WTB 1970 RoadRunner V Code Correct Mopar Drive Shaft Dana
RoadRunner1970
11:45 AM
USA
looking for an original drive shaft for a B Body 440-6 with Dana , if anyone can help me to find or identify which is the correct? Also did the 70 Roadrunner have 1 or 2 horns? thanks
This is the one you need 2996560
Can't tell, should be 50.39 inches center to center of u joints, 7290 u joints front and back, and internal vibration damper, 3.25 diameter.
Allot or shafts are close and will work but if you want th correct one you need to see the numbers on it.
Can you tell me what yoke I need?
Anybody have a driveshaft laying around not being used? as stated above should be 50.39 inches center to center of u joints, 7290 u joints front and back correct one should have 7290 ends and a 3.25 tube. Mopar Part 2996560
Thank You
