PP1RT
^^^^^^The correct torque converter i believe is what he means.The 440 will bolt to the 727, no problem. If the cranks between the two are different, as one being a cast crank and the other being a forged crank, you'll have to have the correct flywheel to match the crank. (Internally balanced forged crank, externally balanced cast crank.)
