Master Cylinder pushrod seal
1967 satellite
11:33 PM
Athens, Alabama
I am replacing the master cylinder on my '67 Satellite. After removing the cylinder and pulling out the pushrod there is some kind of rubber seal on the end of it. Mine is destroyed. Any clue what it's called and where I can get a new one? Also on the aluminum master cylinder spacer there is some kind of foam to act as a filter. Is this also available somewhere?
thanks in advance
The rubber is like a grommet to keep the pushrod in place. If you can't find it you might get away with a small piece of rubber fuel line hose.
For the gasket you can use a piece of packing foam.
Good luck,
Antoon
thanks in advance
Thank you very much!
Good luck,
Antoon
Thanks good idea!
