moparnation74
The same list was addressed in another thread....awhile backJustin- throw it out there! Leanna might not be correct on everything,but after a perusal; it's looks pretty good IMHO. Hey, she wants to be better also. Jeff
My thread lists and shows every finish that relates to almost all pre 70 B bodies.....
http://www.forbbodiesonly.com/mopar...e-for-my-father-my-69-gtx-restoration.127388/
Now I am only referencing OE correct builds here, not people who don't care as to any finish or product...
Starters ZERO powder coat on any part,(no offense CC) the factory never used it and the judges can tell if PC is used....
Paint falls in sheen(%gloss), texture, and finish.....Any natural metal part painted is incorrect...
Go to my thread and do the research....I can also relay other build threads that provide similar information......Pictures etc I have a lot of info....I have spent over 25 years on originality mainly 68-70 B bods....
I am passionate about what I do and I strive to retain accurate information. Hence was one purpose of my thread.....Just click through the pages
Here ya go Jeff hope this answers your question....
Leanna I like ya I love your work and hope this information helps...Dont take offense this is my professional area of choice...
NO sway bars were natural....all semi gloss
NO lower control were GB...all were natural and cosmoline dipped
NO upper control arms were GB...all were natural and a light cosmoline coat
NO tie rod sleeves are SB...all were phosphate(the correct phosphate no one does anymore)
NO backing plates were GB...all were phosphate(the correct phosphate no one does anymore)
NO brake drums were SB all were natural cast finish and proper machined areas(shiny)
Idler arms, tie rods, pitman arm, lower ball joint were a natural cast finish
Center link was natural heat treated steel
Torsion bars are only GB and dipped
Spindles were natural cast and heat treated
Strut rods natural cast and heat treated
Transmission was natural cast steel
Trans X member Gloss Black only
Muffler hangers and clamps were phosphate U bolts hangers natural and hardware nut/washers clear zinc plate
Gas tanks were zinc plated, straps were a galvanized coat you can no longer get done anymore.
MC's depends on the specific cylinder used
Clutch z bar is clear zinc, shift rods and plates phosphate(most debate natural)
Thats a good start....
