B-body SB positive battery cable
mrsnicks
4:28 AM
cameron, nc
I can't seem to find a reproduction that is for small blocks, so I have questions.
1. Does it exist?
2. Will the big block fit/work/connect?
3. Difference between BB/SB?
I don't care about concourse, what's right, I just need a cable that will work.
https://www.ebay.com/itm/321909658253?ul_noapp=true
Is one of the cheaper ones I've found.
Not sure how much difference there is between the big and small block cables but Classic has the small block here but they are expensive!
https://www.classicindustries.com/product/1969/plymouth/roadrunner/parts/mb2533.html
I had a set of repro cables that gave me fits though, car wouldn't turn the starter and went through everything before I finally figured out it was the cable. I could have just got a bad one but for the price, I decided to make my own.
I also bought one of those expensive repo battery cables, had problem of intermittently wouldnt crank, turned out to be a bad crimp, For the price I would buy the one you found on ebay, you could always modify it to fit.
1. Does it exist?
I just ordered one of those for my 1974 RR.
We'll see how it turns out.
