WTB 68-69 AVS Lower Air Cleaner Base
A383Wing
7:17 AM
Somewhere
Feedback: 2 / 0 / 0
My neighbor is looking for the lower air cleaner base plate for the larger AVS carb opening in the center.....we have a smaller base plate here for the AFB style carb to trade.....
If anyone has a line on the larger plate, please contact me, send me a PM here
(The outside of the baseplates are the same diameter, the only difference is the center hole size opening for the carb)
Bryan
Bryan
View attachment 570560 View attachment 570561
I have one from a 1968 GTS. It has a 5 inch hole but the width of the base is 13 inches. Is that wide enough?
No, this is the full size air cleaner that takes the Fram CA-127 air element
The total base diameter is 17-3/4"
Okay no problem- I thought it was smaller than you needed.
I have one that the base is 17-5/8" wide (1/8" smaller) and the carb hole opening is 4-1/4". Is that considered the 2 bbl or 4 bbl air cleaner?
The smaller one is probably for an afb carb and the larger one is for an avs carb- both 4 barrels but different size carb mouths.
