What was this warning light space for?
69 GTX
12:25 AM
Milo, Iowa
So I have a question for you guys. If you look there's a empty spot above the right turn signal indicator for a light of some sort. I'm wondering what would have been there. Here is what I'm thinking about doing. I'd like to put a on light, for my gear vendor overdrive there. I'd like to find a switch to use where the convertible top/rear defroster switch went as a option. So if you know of a speedo with this window for the light let me know. I looked in my manual but they didn't show anything.
nevermind! High beams indicator is over left turning, not right turning.
wiring diagram shows no wire arriving to that pin on printed circuit board
Thanks Nacho. Just looking to see if by chance someone has seen a dash with this spot used.
I may end up making a punch to roll the edges for that opening to match the other openings. To me it's the little things like this that make a build.
The printed circuit board pin can even be used. Just need the molex terminal for it to be inserted on the plug, and a regular socket like the rest
Yes that's what I'm thinking.
lol.... one of my builds; when the nitrous was armed, the "fasten seat belt" light would light...... dude loved it!
