ras roller rockers
stage3
9:15 PM
california
bought some new rockers today for the upcoming 426 wedge motor currently at the machine shop..there from RAS..carrol Shelby used the ford versions on a cobra with 950 lbs spring pressure according to them ,,SS bushed with smith brothers adjusters..generic photo from the web..have used them before..bulletproof..
heres a better pic of these rockers...they now have inventory after 2+ years...
just received the rockers...very nice..bronze bushed..with smith brothers adjusters..
Look pretty damned robust. Me likey. Congrats!
Is there a choice of adjuster style, or is it ball only?
Inventory was always a little iffy with them. Glad to see them back on their feet... again.
Look nice, how would these compare to the “big dogs” like t&d, jesel and harland sharp?
inventory was good last week...u can have either ball or cup..they suggested ball for oiling reasons..which is what I have...retains some oil at all times..cnc machined stainless steel..
all those I believe r aluminum rockers...these r cnc'ed SS with bronze guides..probably not as lite as those but much stronger and reliable..just make sure the oil has plenty of zinc'phourus....
these new 1.6 ratio RAS rockers r going to change my lift and duration .. how will that change my final numbers..both lift and duration,,and at .050..blurry pic..lift is .650,,.651,,,,.296--.303,,,@ .050.263--.270,,,108 center..based upon 1.05 stock rockers..
They look nice. RAU's website is crap, what do these cost? Part number?
Same cam I’m running, lift will come in around .693/.694 not sure how the 1.6 effects the duration numbers someone will chime in.
according to RAS,,when using 1.6 ratio arms..because of the lash , u will end up at a true .650ish lift.. if the arms add appx .033 lift above the stock 1.5 ratio,,,minus .028 lash gap,that would be .655,,,duration on the other hand is a completely different formula not currently at my fingertips..
