68 HEMI GTS
Mechanical outboards will flow a bit more than the vacuums. Easier to jet. Unfortunately they have preset idle metering using weep holes on the outboards vs the vacuum outboards having fuel adjustment. It Is easier to step up to a 500 cfm center with the mechanicals. Either set up your crusing on a very small center carb, should be a wash as far as that. You can slow the vacuum carbs down to suit what the motor will handle. Being a stick car the pumpers should be funner if the motor will handle them when you go WOT.
I have this pair I built for the roadrunner. I may put adjustable idle circuits in the outboards depending on how they act. Center is a 4412. I don’t expect them to be any faster than the vacuum carbs, just something different. Plus I plan on going back to a clutch in the near future.
