FOR SALE 1974 440 wedge
Brandy
Jack Stand Racer #6..and proud of it!
10:39 PM
Salisbury, Vermont
Feedback: 20 / 0 / 0
Selling a 440 out of a motor home. It ran well before it was pulled. The engine is missing valve covers, valley pan, dizzy, oil pan. Can include a set of factory exhaust manifolds. It comes with a stock 440 intake and water pump and a 600CFM Holley.. this engine is an "RB" block, cast crank, "902" heads,8.9:1 compression,4.32 bore/ 3.75 stroke, built in Trenton 6/4/1974. From what I have gathered so far, the open chambered "902" heads flow as good or better than the "906" heads. This motor has the raised rib along the sides of the block just above the freeze plugs, thicker ears, 10% more cast iron in the block. It has been kept in the garage and covered and coated with oil to defeat rusting and turns freely.
$ 400.00 firm.
309997-b196cd9666c4fb86c958b6d67c6eb4a3.jpg 309998-5047f9665f0aa81298e569f7c9a707f0.jpg 310000-19381d2950b9e4300bfcd15506c5f425.jpg 310001-76c46bdb9244b8f6d5fd2381b9026b32.jpg 310003-3b16a349e3e16c8596a954c9bae2605b.jpg 310005-4aa81af4f25d33c464382621cd171dcd.jpg 310006-3e578c7ce6c5e8eb5f845f8d46e6f5d1.jpg
I think so too. It should be a good motor. It ran well before removal and the MH had 57,000 miles on it. I may even have a tranny for it..
Can be crated up and shipped via Fastenal...
Keep in mind that it's a -8 block and is not a good candidate for racing purposes. it will be just fine for street use and minimal boring over stock.
