- 10:47 AM
- Dec 4, 2009
- Pasadena, Texas
I noticed it, so out came the cut off wheel.....those bearings didn’t stand a chance!
I use a clamshell(bearing splitter) also, get the 2 halves tight against the bearing and slow pumps on the press !
If I'm thinking it's the same thing, yeah it's pricey.....and not gonna buy one now. Just don't do enough work on rear ends anymore to warrant spending the money.there is also the type of puller that comes in from the top, not sure of its name but they are pricey.
You can lock the center in a vise, use a big adjustable (or the tool you've already made !)wrench to hold the yoke while you loosen or torque the nut ..... OR .... you can make a jig out of steel tubing (1/2" maybe) to bolt to the center section to keep it steady while you work on it ...I'm wondering how you break the pinion nut loose on these center sections and retorque them when it's on the workbench?
Here I am and my setup today, getting the nut off my 742 so I can change the seal. Attached a angle iron to the yoke and had a pipe sticking out the side of the car to stand on. I think I hurt myself!
I'm wondering how you break the pinion nut loose on these center sections and retorque them when it's on the workbench?......
