2quick
Bought a Milodon external oil pick up for my 440. Supposed to work with stock motor mounts and they offer another version for motor plates which i did not get. It Uses the Milodon oil pump, cover plate and pan so you think it would work together. Not sure what Milodon had in mind but no matter how I run the hose it doesn't work. The instructions say to have the line turn up out of the pump so oil doesn't drain back into the pan causing dry starts but that makes it worse and the hose is like a foot to short togo around under the engin. I am running a QA1 cross member and Borgeson steering box but I would have thought they would help the situation being they are both much smaller then stock stuff.
Anyone have some pics of how they routed there single oil line from the pump to the pan?
