Ski 61701
- 11:38 PM
- Nov 21, 2016
- Bloomington Illinois
Unlit propane torch
True, hand over the carb tells you if you are super-lean which is usually a vacuum leak, but unfortunately it doesn't tell you exactly where the leak is.For simply confirming a leak, and better than any spraying of stuff IMO, is simply putting your hand over the carb.
Well, I think you can find intake leaks ON TOP, but underneath is a whole other story. I'm about to go hunting for what I "suspect" is an intake leak on the bottom of the intake in the next couple of weeks using a method someone here showed me on the Hughes site.... PIA, but it should tell me for sure if my intake is square.I have never had a carburetor gasket leak, ever. Probably snitched carbs 50 times. Next is an open vacuum port, leaking vacuum line. Pretty easy to find those. Finally, and the one that I find to be the case more that anything, intake gasket. More often than not, you cannot find the intake leak with flammable aerosols.
.........And, every intake leak that I have found has always been on the bottom.Well, I think you can find intake leaks ON TOP, but underneath is a whole other story. I'm about to go hunting for what I "suspect" is an intake leak on the bottom of the intake in the next couple of weeks using a method someone here showed me on the Hughes site.... PIA, but it should tell me for sure if my intake is square.
I think all I had was Ether (starting fluid), it worked for me, and it works great to seat a bead on a tire.Used Ether spray back in the day in the Army....
