- 3:43 AM
- Oct 16, 2014
- Salisbury, Vermont
I purchased a 1973 440 passenger car 440 that was installed in a 1986 Dodge Power Ram. I suspected that it had been warmed up some. Now that I have it apart down to the bottom half there are several clues. First, there was a stuck lifter which was ground into a cup, along with the cam lobe. That set of valves were black and oily. I see now that it is the source of the tickity tick noise while running. Also the cam is a Crane HMV272-2 NC, the main caps are stamped "30", the crank is stamped .10, and the rods are cast with a 488 number. One piston appears to be new as the rest are carboned up. The motor had a nice chrome bits attached like the timing cover, valve covers, other bits..it had a Edelbrock Performer 440 intake and a Holley 750 CFM double pumper carb. It has the 346 heads . Any conclusions?
