4 prong ballast with electric choke
SlinktRR
6:45 AM
Dallas TX
my car now has an m&H harness with leads for the 4 prong ballast resistor. So i have the stock 4 prong with a Mopar chrome box, and it works great with a firecore dist and blaster 2 coil. The harness is great, everything works again.. even the clock on the tic toc tach, which i was surprised by. However, i plan to run deeper into the cold weather this year and need to hook the aftermarket electric choke back up for faster starts.
Can i splice off one or both of the 12v side of the resistor or somewhere else? Also, anyone know what the significance of the 4 prong is vs. the 2? Should i just cut the m&h connectors and go back to a 2 prong?
Factory made it straight from the blue ign 1 power line. Since it seems you got a 70 and should get a blue field wire to the alt, you can get it from that line down the harness tape to make a short line wire. On 73 and lates it was made on that way to feed the electric choke control unit mounted on one of the intake manifold bolts
Thanks, so if I have this correct...if I'm using the chrome ECU, it is 4 wire ECU and if the engine harness uses a 4 prong ballast resistor connection, then only one 12V lead to that ballast resistor will be hot and the other lead will be 0V.
For the choke I should splice the blue field wire on the alternator which would be 12+V, similar to the ballast resistor feed... but will not be in the ECU circuit.
we usually run the power for the choke off the wiper motor connector from the bulkhead, that line has a fuse in it already.
no need for that.
don't overthink that. Just splice it from the blue wire wherever on engine harness and done.
ballast is allways hot on both sides, at diff voltage rates depending on the ign switch stage, but allways hot
Thank you Nacho, blue field sounds like a good power source I'll tie into there.
this is what factory made on 73 and lates ( 73 diagram ilustrated ) I made this diagram long time ago.
Engine harness got the provision set for the choke control unit on the run up to the alt brush
Who knows how to test the choke control switch? Should it always have continuity between the two spade connectors?
I found it just after I posted my question.
