points to electronic ignition 1967 Plymouth GTX
cmkryzer
2:55 PM
Minnesota
I am doing a conversion from points to electronic ignition, I bought and have the updated wiring and a new MP distributor, also the wiring is set up for 60 amp alternator. Question is , what more do I need to do this upgrade
Thanks in advance
If it was a complete kit should have come with the ballast resistor.
Ok it does have the resistor. But now the kit is set up for a older system, I have the upgraded wire harness that has the 70 and later voltage regulator to accept the higher amp alternator, so has the 2 prong plug . So not sure which regulator and resistor I should be using, as the plug for resistor is different then the what the resistor that came with the kit?
