- 6:46 AM
- Jul 17, 2008
- South Jersey USA
looks as if a few of us have the rare cluster indicator delete option........
It also begs the question of differences between rally or reg. dash.
Could this be an assembly plant thing? Where were you guys cars built that have the lights blocked off?
Just the info I am looking for. I would take just the yeses and the no's. And the most I would take for my answer.Can't verify for 68 Mo, but my 69 with fendertops do work in cluster also.
Fast flashing would indicate a failed bulb as you describe, but If everything else is working a failed ground also causes rapid flashing. They work on resistance, so a 552 flasher is an easy try. Unplug the fendertops and give it a try.
Back in the "old days" remember when you hooked up your tow vehicle to a trailer for the first time?
You found out quick you needed a HD flasher, as you added more resistance.
Good luck!
Sorry, guess that wasn't a yes or no
Great answer. Thanks for taking the time to post............................MONO. My 1968 had factory fender mounted indicators and the bulb holes in the instrument panel had paper tape over them to prevent the insertion of bulbs. I removed the tape and placed bulbs/holders in them and now I have both. Any other 68 owners with both are most likely the lucky recipients of the actions of previous owners or a factory screw-up.
Good to hear. My Son lived in C.B. and the Omaha folks called it " Counciltucky" .... buncha Ne. snobs !!!.lol...........................MOOriginally from Council Bluffs.
Yes I did, and as you can see, there were two answers !! Happens every time !! LOL...............................MODidn't you ask this question a couple of weeks ago?
Or burned out bulbs---as I expect I will find in mine...........MOlooks as if a few of us have the rare cluster indicator delete option........
