Challenger340
- 11:08 AM
- Mar 4, 2014
- Moyie Lake, B.C. Canada
Depends upon the location of the "wear" in a BB Mopar Lifter Bore is ?
Typically the worst, or most worn part of the BB Mopar Lifter Bore is concentrated in the very "short"..... and load bearing area directly below the Oil Gallery ?
The more the Bore is worn in that area.... the faster it will continue to wear, and time to bush the bores.
Go have a look visually with a flashlight.
Look at the "half moon" shaped wear pattern from the bottom of the Lifter Bore UP to just below the Oil Gallery. If the wear in that area exceeds .001" OOR from the rest of the Bore.....
or,
the top of the half moon wear pattern is more than 2/3 of the distance to the bottom of the Oil gallery... time to bush.
If the Lifter Bore is decently straight & round within .0005"... including below the Oil Gallery, then .0025" to .003" actual Lifter clearance will run.
or,
