I'm back in the game!!
Great day at the track today. High humidity and Barometric pressure was dropping like a stone. Sweating just sitting in my car and it was only 69 degrees,
Sporting the original LITTLE FINSTERS RACING TEAM LOGO FROM WAY BACK IN 1973 that I started motocross racing then transferred over when we started drag racing in 1975
13221703_10205664130556829_5836162225046615201_n.jpg little finsters racing team garage original.jpg.png
Back from the body shop and getting it out this Saturday. My little guy pulling it into the trailer.
So after reading the plugs and checking the readings on all 8 cylinders, would you believe #1 wants a 101 holley jet which equates to a 130 in a BLP jet (orifice size) and my number #6 wants a #86 jet and #8 want s a#85 jet.
wheels up, with a 1.26 on the back tires.
5.48 in the 1/8th and 8.69 @155.12
Running C14 and only 32 degrees of timing. Should be 35 degrees.
My Hotrod was working yesterday for sure.
.007 light 8.94@150 1.267 60 foot on the back tires or something under the car.
How do yall check your plugs ar the end of a run? I'm running 727 reverse manual valve body. Don't think it's a good idea to just cut the ignition off in 3rd gear doing 100mph?
the Orig. poster has been on pretty much a permanent time out
he's been gone for a long time
he won't be answering anytime soon
440ronnie67:
Here is a way to do it:
Once on the return road pull off to a safe area and shut off engine ASAP.
Pull a plug (or 2) for inspection.
Best way to do if you dont have a clean neutral shifter.
440ronnie67:
Thanks bud, Kinda figured but....
440ronnie67:
^^^^ This and just take 2 extras with you to put in. You can read the other two when you get back to your pit.
