SOLD Misc. Pushrods, Valve Spring Retainers, Shims
khryslerkid
1:55 AM
Hanover, Pennslyvania
Feedback: 20 / 0 / 0
Miscellaneous pieces here.
Comp Cams 741-16, 10 degree retainers. Comes with Comp Cams 627-16, 10 degree locks, 2 groove and 4 groove. (New, never used)
$60 shipped in the US only.
Spring shims
4740, 4746 have only 13 shims per pack. All the others are 16 per pack.
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
$5 per pack or $25 for all shipped in the US only.
440 Source Rocker Shaft Shims. 127-1020. $20 shipped in the US only.
Harland Sharp Rocker Arm Spacers. SPO47K
.047" Thick .875" I.D. $5 per pack shipped in the US only.
Used Pushrods. $35 per set shipped in the US only.
This set has one pushrod that has been cut but not all the way through. It could be welded or use the others for repair or replacements. $25 shipped in the US only.
Feel free to start a Conversation with any questions.
Are the Comp spring retainers and locks still available? Those should be the correct retainer and locks for the 911 spring, right? I'm going to use these on stock 906 heads for my cam change.
Ted
I’m interested in the shorter pushrods but l don’t know what the overall lenghth would b what’s yer zip
Ted
PM sent
PM sent
D
View attachment 606631 View attachment 606632
Spring shims
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
Spring shims
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
D
Spring shims
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
Spring shims
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
Spring shims
4740 .015 x 1.640
4746 .030 x 1.640
4752 .060 x 1.640
4737 .015 x 1.437
4743 .030 x 1.437
4749 .060 x 1.437
Retainers and Locks are SOLD!
Thanks FBBO
Shorter pushrods are the ones I need .8.66 effective as u call them.l need a address i,m not on paypal.but we have amopa r ace in two weeks at eddyvi ok please contact me
I'll tell you what I'm going to do. (These endless messages are too much)
You message me your address and I'll send them to you. When you receive them, look on the postage stamp for the cost of shipping and send me your check for that amount. My return address will be on the package.
Double check your address to make sure it's correct.
KK PM sent
This is Jackson.l have t received the pushrods.the r was some sort of snaff u ,should get them tomorro w and I 'll zap u a check
Hi just checking to see if you still have the 9.08 pushrods, if so I can
