69SKCharger
Not sure where this belongs, could be fuel or electrical, but I have a stumble that stalls the car. It's a 383 HP. Stock with exception of a RV type cam and edelbrock 650 AVS carb. It has an old accel electronic ignition box and distributor.
The problem is that during normal acceleration the car will stumble as though fuel starved or spark is shut down. Its actually kind of violent with the std transmission. Usually it restarts itself, but has completely died on me with difficulty restarting. Its not consistent but random.
I have cleaned the carb, reset the floats, set the idle air mixture and checked timing. The fuel filter and pump are new, as is the tank and pick up.
After all that, I still had the stumbling, after driving for a while, it seemed to go away, but suspect that's temporary . Looking for suggestions on what to try next.
