Hemi Steve
- 1:46 PM
- Jun 15, 2018
I'm new to this forum as I have an E body 73 Cuda with a 528 Hemi. I did not build this car so I'm slowly working through the details of the car. I have had the car for about 2 years now and am not happy with the rear axle. I have believed that it has a locker in it because of the way it drives. my big issue is slow tight turns where the tires squawk and skid. I also get a click as I enter a turn at normal driving speed. I have attributed that sound to a locker unlocking. I've never had a locker so it turns out I have been misinterpreting the behavior and sounds. I have decided to change the "locker" to a limited slip to deal with the tire scrubbing and squawking. So to order a Truetrack I needed to know how many splines the axle shafts have. I pulled an axle and was very surprised to find they are 23 spline. It took a lot of searching to find that there are no Truetrack's, lockers or spools that use 23 spline axles. The axle housing is likely a Strange S60 (possibly a Moser...not totally sure as I don't know how to tell the difference). I believe it is a Strange or Moser because a true Dana would have the build date and BOM number stamped on the right tube and the numerals 60 cast into the lower right gusset. My axle housing has none of that. This morning I pulled the cover off to see what's in there. It turns out it is a Powr-Lok with a date stamp 10 1 68 A and a part number 25124 X. That decodes to a 23 spline Powr-Lok that was apparently used in trucks and B body Hemis and 440's in the late 60's.
So, my question is does a Powr-Loc behave as I described or is there a problem requiring a rebuild? Or is the Powr-Loc a POS?
Steve
Steve
