727 Transmission lines
roadrunnerh
1:41 AM
Pittsburgh, PA
Having a tough time here. Anybody have any tips or tricks to install these lines on my 68 RR?
Gotta hold your mouth just right. First off, make sure the ends are capped to keep out any crud. I like to snake them in from the front because it's about the only way to get em in if the motor and the trans is already in the car. Lifting the driver's side of the engine up some can help....
Been a very long time since I snaked any in.....but iirc, I lifted the engine up and that helped a lot. One at a time was easier. You can at least flex one at a time to get it where it needs to be. Having the front end up helps too. Got a lift? I used a pair of homemade wood stands once. They were made so the tires sat on them.
Glad you got it... I used pre-bent lines for my 68, and I had to tweak the bends under the car as I put them in to get them to fit right...
