New bullet for the "Brick"
Last night I blew apart the starter to check it out. It's been in the car since 1991 - never had a single issue with it. I still need to split the gear (reduction) box but, the brushes are still good and the armature looks good too - so far the only issue I found is that the contacts are worn pretty good (see close up pic) This is typical for these Nippondenso starters and the contacts are cheap and easy to get.
Update - I bought the block from my friend and took it to Bob Mazzolini to get it sonic checked. This one is much thicker than my first block, Here is the worksheet. I originally wanted to go 60 over but have decided to err on the side of caution and go 30 over. It was cast 3/2/72 and is stamped H440, HP2 - so I'm gonna have a legit HP motor! (yea I know it's meaningless) I've spent $725 to this point on the block(s)
Update - I picked up set of 10 inch wide Welds to replace the 8 inchers I ran for years. All (or most) of the NHRA stock eliminator racers run 10 inch wheels with 9 inch slicks because you get a better contact patch. Those guys know how to make a car go fast so I figure I'd make the change - I'll need ALL the traction I can get with the new motor and I did notice the outer edge (about 3/4in) of my tires weren't touching the ground. I sold the 8 inchers (bare pair in pic) at MATS last weekend so there's no turning back now.
Weight with driver for this car is 3650. Best 60ft was 1.45 - with all the changes I'm shootin' for mid 1.30's.
My wife named the car but I've been sayin it has the aerodynamics of a brick for 20 years!!:rofl:
You painted it on the door.I still street drive so I have kept the body free of any painted name or stickers,just on the 1/4 window.
should have asked about our bulk head washers when you ordered your girdle kit. we have them with a double o ring so they seal both the inside of the pan and the outside of the pan.
Please tell me about 'em - not exactly sure what you mean.
here are the bulkhead washers we make. they provide a dual oring seal on the oil pan for zero leaks. each o ring is contained in its own groove so there is no extruding and no weeping forming a perfect seal.
Those look real NICE! I used the white nylon to go with the o-ring on the an fitting that comes out of the pan.
Not much of an update but I got my Jesel belt drive system on Friday. This is one item that I probably could have done without but it's something I really wanted for this build.
This car was originally equipped with A/C and this hole in the dash housed the center A/C vent. I have removed it and I'm going to install a panel to hold some indicator (idiot) lights.
I made the panel out of aluminum and I'm still figuring out how I want to lay it out (cardboard pattern) It'l have a large oil pressure lite, and 3 small LED's. One for fuel pump (blue), one for water pump (green) and one for charge (alt) indicator (red)
Still have to decide which O/P light to use - the one with the chrome bezel uses a incandescent bulb and the other one is a LED that is normally used as a marker lamp for semi trucks and trailers. The LED is much brighter.
Hello theman440 wondering how are you planning on running your oil pressure light, I need to do the same thing on my 65 satellite, also where are you purchasing those lights?, thank you in advance, Jay.
For the O/P I plan to use a 20psi n/c switch to supply the ground to the light. The positive side to ign "on", So anytime there is less than 20psi the light should be on. The larger O/P light I've had for years and I can't remember where I got it. I've decided to use the smaller LED - you can buy them from any Semi truck parts/accessory store.
Link to O/P switch - https://www.summitracing.com/parts/qcr-61-735
I got the small LED's from McFadden Dale
