Mike Gaines
- 4:22 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I have begun my quest for a 9.999 time slip.
My personal best so far is 10.15 (@131.54)
The Wallace Racing Site (which I think is pretty accurate) says I have to have about 750HP to push my 3800lb Coronet to a 10.158 ET.
I do not want to try to make more horsepower with my 2 bolt 440 block. Although I have a steel billet girdle plus steel billet main caps I am afraid to go over that 750HP and blow out my bottom end...so...
Weight Reduction is the answer.
Trunk Lid: I currently have a steel deck lid. I have on order a 8lb pin on fiberglass deck lid and will install it with hood pins.
Batteries: In the heat of the summer I run Two (2) Optima Batteries to make sure I have plenty of juice to run my electric water pump and electric fans in the staging lanes between runs to cool down the motor...I am removing 1 of the batteries for racing this Oct thru Dec when it will only be around 75 (or less) during the heat of the day.
Driver's Seat: I have already removed the passenger seat and I have bought a lightweight fiberglass race set to replace my very heavy Recaro type upholstered seat.
Padding and Heat Insulation under the carpeting: I am removing all of the "padding" and all of the silver "heat shield" under the carpeting to get rid of that weight.
Front and Rear Bumper Brackets: I have trimmed almost 75% of the weight out of my stock steel bumper brackets.
Fuel Cell: I have replaced my 10 gallon Harwood Plastic Fuel Cell with a 4 gallon Aluminum Fuel Cell. I always ran 5 gallons of fuel in that 10 gallon fuel cell because I didn't want the gas sloshing around and uncovering the pickup.
Now, the much small Aluminum fuel cell ( it is lighter PLUS it is only 10" square in measurement) I can run 3 gallons of gas and not worry about it sloshing away from the pickup. ( I use one gallon of gas on each run, including driving up to the staging lanes, pulling forward, etc, doing the water box, making the run and returning to my pit.
I already have fiberglass front fenders, hood & scoop, front and rear bumpers. The back seat is already out (of course). No heater or defroster. aluminum heads. No exhaust.
For the time being I am going to leave my alternator in the car. I do have a 5" pulley on it. I don't want to worry about the "juice" to run the MSD, fans and water and fuel pumps.
I am doing all I can do without "gutting" the car. I want to leave it so I can easily put stuff back in and have it 100% practical for street use. I still have regular crank up glass windows, full dash, headlites, turn signals, brake lites, etc. I is currently licensed with the State of California and insured with Hagerty and I can drive it to a car show if I want (after I hang on the exhaust system.
I figure I have to lose about 160lbs and have "good air" in the range of 500' to 1000" feet adjusted altitude to hit my 9.999 time slip come this Oct, Nov and or Dec.
I will then put about 20lbs back in the car to slow it down to 10.00+ET so I don't have to do all the necessary stuff to certify the car (and me) to go faster than 10.00 on a regular basis.
My first outing to test out all this stuff will of Sept 15-16 Summit Series race at Famoso.
The air will probably be in the 2000' to 2500' range so I won't hit 9.999 then but I will then know if I can do in in Oct with better air...
Wish Me Luck.
Wish Me Luck.
