Phantom440
Hi all, I hope you’re doing well!
‘72 Coronet, 8 1/4 rear.
I’m trying to get the rear and leaf springs out for wagon leaves and 8 3/4, and I’ve managed to remove the rear shackles and disconnect the shocks. Working my way forward, I get to the front leaf spring bolts, and they ain’t moving. I think it’s a 15/16 nut facing toward the outside of the car, and what looks like a smaller diameter nut toward the center. I put a breaker bar on the outer nut, and even stood on it (and I’m about 215lbs) and it didn’t make a lick of difference. I blasted it with Liquid Wrench about an hour before I got to that area, and nothing. Am I doing it wrong? Does the inner nut (closer to center of car) come off first and then I bang the bolt out outward? There doesn’t seem to be enough room to do that.
Also, I found out someone had half welded a nut on to secure the Driver’s side shock at the bottom. Really glad I found that out now, as this is to be my wedding car.
Anyway, any help to try and get the front of these springs out will be much appreciated!
Thank you in advance!
