Dana67Dart
Hello my B-body Brethren!
Just picked up a junk yard 8 3/4. It was in a bone pile so I don't know what it is out of and some of the measurements are not adding up from the various sites that list such. The yard didn't have but 2 mopers in the 60 to 70s range, one was a 68 Belvidere and a 70s duster with tubs neither had a diff in it.
Most things add up to 70 to 74 E-Body but some things don't add up...
Details:
Breather is up on the hip of the housing not on the flat of the tube.
Large bolt pattern
Left hand threads on left axle
OE axle bearings
Both axles look identical
One axle measures 30 inches on the end of spline to out side of wheel flange.
65 to 69 C body or 70 to 74 E body or 65 to 70 A100
One axle measures between 30 1/16 to 30 1/8 end of spline to outside of wheel flange.
65 to 66 imperial?
Perches under housing
742 with Sure Grip / Power-Loc gears say 12 / 66 for date.
There was no tags on the diff, probably was apart at one time.
Small flange u joint
Drums have springs around the OD
Housing measures 56 1/2 out side axle mounting flange to outside mounting flange.
70 to 74 E body?
Purch CL to purch CL 46.
65-'73 C BODY
70-'74 E BODY
Brakes are 11 x 2 1/2
What do you all think?
Also everything but the center section will be for sale in a week or so. PM if interested before its posted.
Details:
Large bolt pattern
OE axle bearings
65 to 66 imperial?
70 to 74 E body?
65-'73 C BODY
70-'74 E BODY
