Jung
Has anyone experience with these? I just fitted a set into my 505 stroker and there's quite a lot of mechanical noise. Not the ticking you get with a bad lifter, more like a loud rustle that seems to diminish a bit with RPM. I've gone through and set the preload at half a turn from zero lash a couple of times just to check.
It's running a Comp Hyd Roller cam, smiths custom pushrods and Harland Sharp Rockers.
Might be completely normal, I've just no experience on what this sort of set up should sound like!
Cheers.
Cheers.
