missing electrical harness
All4rocks
12:09 AM
Grass valley
There are 3 harneses that connect at the firewall. Top one goes to engine/regulator. Bottom one goes to Headlights. I am missing the middle one. What does it go to?
Not sure what you have but on my 68 charger top is wipers, middle is engine, bottom is headlights.
Refer to the FSM to be sure.
What Rebel said....you're missing the top plug which is the wipers. The engine harness goes in the middle
My engine plug Will not go onto the middle one maybe I have the wrong one. I have two of these harnesses that came with the car and they both look the same. they will fit the top or the bottom one
I suspect you do. Each one of those plugs has a different locating slot so they cannot be plugged into the wrong connector. At least that's how it is on my '69. I'd suspect they are all that way.
Ok i found out from previous owner that the engine harness was from a 70 cuda. So what is the correct harness i need? I also have the upgraded electronic ignition.
