Ways to increase performance and HP/torqu without machining heads/crank or major engine dissassebly
I think this thread is losing sight of what you are trying to achieve.
Good thought there.
If you think it's got s small cam, it might not be worth doing much to verify it. There's value in knowing, but if it's been reground already it's not going to be a really good candidate again to go bigger. So now your odds are less that finding out that you can do anything about it. If it were me I'd just clean it up, add an ignition, maybe some headers and good tuning, and then concentrate on the body.
A lot of people forget, those numbers achieved (290HP) were from cherry picked dyno runs from multitudes of engines being ran in an ice-cold dyno cell; no accessories, optimal tune-up, and open-exhaust. IAT's and Coolant Temps, would have also been optimal.
A mechanical fan alone, can draw around 30-hp @ 5,000 RPM (Clutch is OPTIMAL, little to no difference vs. electric). Modern alternator and mechanical water pump, 12-HP @ 5,000 RPM. Coolant temperature, 140* increased to 200*, pulls another 10-HP (1-HP + loss per 10*). Adding to that last note, in a car, under a hood, this would negatively affect the IAT temperatures and further loss of power would occur. Manifolds vs. Headers, 20-HP +/- entire curve. Cheap muffler (OEM) vs. Good muffler, 10-HP +/- entire curve.
That's 80-hp, that's why it was a 'wow' moment in 1972 when going from Gross to Net figures. Minimal power loss from compression, most of the damage from more realistic power-measuring. Could you imagine if they measured RWHP!? 390 HP 440 six-pack, 300 rwhp. You see why Gross ratings were favored. In 1972, the 440 'high performance' net figures were down rated @ 290 HP from 375 +/- HP Gross. The cars were heavier, power was down slightly (few percent with CR drop), so it's pretty obvious why perceived performance was lower.
IQ52 took a pretty much bone-stock 78' 440 (7.8:1 CR), added headers and an Eddy carb, made 300 HP at the crank / 430 ft/lbs of torque off idle. . . . . next step, 387 HP / 450 ft/lbs from a .509 MP cam, M1 intake, and 850 carb. ..... 450 HP after switching over to some ported Iron heads, no other changes. HP per $ is really tough to beat - - - - Don't try that with a Poly. That's why it may be better to do budget-upgrades, upgrades that 'free up' HP and spend the real money on building a 440 instead if you want power.
Yes, good price IF it is in good working order.
Upgrade, maybe.
I don’t if it would fit ether
I posted just to show it
View attachment 650435 Nitrous, and when you blow all hell RB time.:thumbsup: This was in a friends 65 Dodge Coronet 4dr ran low 13 teens 100 mph plus with 100 shot of Nos.
If that filter has foam in it , get rid of the foam, sooner or later it "will" deteriorate and start putting little pieces in the carb and intake.
They do make qa pleated filter that can be conformed to that base, made my own top.
