SOLD Parting 67 Coronet 2 door
gregpurcell
12:26 AM
Savannah Georgia
Feedback: +7 / =0 / -0
I'm parting out a 67 Coronet 2 door 318 ac, auto. With the exception of the passenger door, there are almost no usable body parts. No front end, not grille. Front suspension and k frame is there, engine/trans are available for $375.Located in Savannah, GA
DSC03120.JPG DSC03121.JPG DSC03122.JPG DSC03123.JPG DSC03124.JPG DSC03125.JPG
Would you be willing to cut out the side scoops from body line down and from door jamb to 8" behind?
Would you be willing to cut the passenger side rear shackle mount off the car?
I believe its called the shackle perch. Just the part where the bushing and shackle go through the frame.
If the frame rails are good, I will not be able to. I have a friend looking for good rails. If they are not usable whole, I could cut the perch.
so, from the top of the body line, the inside of the door edge, 8 inches back past the scoop
to just under the middle body line?
So if you could /willing to drill spot welds inside of door jamb and back to locations in the pics? I actually only need the drivers side...as you can see in the pic...
Did you ever figure a price? Trying to keep it small enough to fit in an average box...
Thanks Greg!
Greetings: I am interested in the left rear quarter panel taillamp reinforcement that is attached to the left quarter panel. Can it be removed and what would you ask. Please
avise. THANKS! Jack Gocala
