If they are good that far back. I'll checkWould you be willing to cut out the side scoops from body line down and from door jamb to 8" behind?
If the frame rails are good, I will not be able to. I have a friend looking for good rails. If they are not usable whole, I could cut the perch.Would you be willing to cut the passenger side rear shackle mount off the car?
I believe its called the shackle perch. Just the part where the bushing and shackle go through the frame.
Do you mean the INSIDE rear view mirror? I'll look. I also might have a couple more here.What is the condition (picts?) of the rear view mirror?
Yes, the inside rear view mirror. Thanks.Do you mean the INSIDE rear view mirror? I'll look. I also might have a couple more here.
How far back (each way)from the hole?Would you be willing to cut the passenger side rear shackle mount off the car?
so, from the top of the body line, the inside of the door edge, 8 inches back past the scoopWould you be willing to cut out the side scoops from body line down and from door jamb to 8" behind?
I'll get them off this weekend. They may be usableHow much for the bumper guards? And condition?
Passenger mirror is a plastic repro. Drivers side has pretty nice chrome with a few pits. $30 shipped for the driver side, PM me with your email address for picsWhat condition are the side view mirrows and how much shipped tp 15642
So if you could /willing to drill spot welds inside of door jamb and back to locations in the pics? I actually only need the drivers side...as you can see in the pic...so, from the top of the body line, the inside of the door edge, 8 inches back past the scoop
to just under the middle body line?
Ok, thanks.I'll get them off this weekend. They may be usable
I think 4 inches each way would do the trick. Also how are the hinges for the doors? Might be interested if the doors dont sag.How far back (each way)from the hole?
The drivers door sags so bad it won't close.I think 4 inches each way would do the trick. Also how are the hinges for the doors? Might be interested if the doors dont sag.
