Engine and transmission numbers
tommytmopar
2:09 PM
Decatur AL
hello I’m trying to figure out my engine and transmission. I may have a friends engine we’re not sure. His dad moved engine and transmission around a lot in old Mopar.
The engine is a 69 440 hp 18 spline output. When I had it rebuilt at Hensley late 90 s the engine had a six pack cam and six pack rods.
The numbers I can find both sides 2536430-7 passenger side of car engine has build date of 1-13-69 also a circle of dots and DN. I can’t find what would be the vin serial number. I looked at the back of the engine topside but I think that’s on 68 s. Nothing there that I could see. Any help enlightenment appreciated. My friend has a six pack bee so we’re trying to see if I have his numbers engine.
The trans is a hemi 4 speed takes 5quarts of fluid. Listed as heavy-duty in service manual. The numbers are housing:97622 DC on the little pad: 8c152162 and 0170. Thanks in advance. Tommytmopar.
On my 69 rr engine, the partial vin, 9Axxxxxx is stamped (not cast in like a casting number) on a pad just above the oilpan rail, just rear of the motor mount, on the passenger side of the block. Partial vin is also on my 727, and if memory serves, on the Dana too.
Thanks I give it a look I’ll bet mine is there as well.
The 9A in my vin indicates 1969, lynch road assy.
The 8c152162 could indicate 1968, and where the trans came from, the other six are likely a partial vin.
