Painting engine compartment separate from car?
CompSyn
3:25 PM
Pacific NW USA
Looking for some recommendations in trying to figure out the best way to paint my engine compartment now and then the rest of the car later?
Below: Picture of car in its current state.
Body color: F5 Limelight Metallic
Objectives:
  • Want a factory "look" with modern paint. This car won't be a 100 point OE gold competitor. I'm not concerned about using single-stage paint, or duplicating paint runs and shadows, etc.
  • I would however like to duplicate things like painting over the grey seam sealer that goes between the fender and inner fender as the factory did.
  • I would also prefer to have the engine compartment shot with the fenders bolted on and aligned so that the bolts are painted in place and then not disturbed with the potential to chip the paint if they were painted off the car.
  • The concern with my objectives is with paint lines when it comes to painting the rest of the car and the overall look of the paint job; overspray between the seams and the like. My body guy thinks it will be best to remove the fenders later when the rest of the car gets painted but I'm not sure he completely understands my objectives.
So I guess it comes down to compromise between what looks best versus what looks correct?
What have you guys done with your cars? What are your recommendations?
I realize in a perfect world, the whole body shell would get painted all at the same time. Unfortunately budget dictates me painting the car in stages.
Pic of car as it sits now, at the body shop...
I sprayed mine with urethane. I think it was called Nason Fullthane from Orielleys. Used a wet look hardener. If you want the factory look, then runs and orange peel are a must.
I painted mine masked off like this: Paint the fenders off the car and paint the bolds separate just making sure that you keep the paint to a minimum. Buy a set of the nylon lined sockets to install the bolts and you won't have a problem.
Yep did my 64 Dart like zyzzyx. As you can see the fender rolls over the inner fender so when the car is put back together you really won't see mask marks. At the cowl part line you will never see them.Like you, I wanted to get it up and running to drive and do the rest of the paint when money allows.
Did mine the same way as the other two. Just find a good line or separation to tape on.
I would recommend you get all your paint at the same time just so,you don't have any color issues.
Agreed. It was the new guy or less expierenced guys that painted under the hoods and insice the trunks. So Runs, dry spots, orange peel, are all exceptable. Remember that the hoods were up when they painted the hinges, so there is only some overspray covering behind the arms. The assembly line doesn't stop, so what got painted varies from a good painter to a poor painter, and of course there are Hung over Mondays paint jobs too.
Like said just find a good line to mask. Easy peezy.
