FOR SALE Comp solid roller lifters set BB
2quick
10:20 PM
New Jersey
Feedback: 5 / 0 / 0
Endure-X™ Solid Roller Lifter: Chrysler V8 383-440, 426 Hemi
Part: 830-16
Quantity:
Application – Chrysler V8 383-440 and 426 Hemi
Diameter: .904″
Weight: 122g
Pushrod Seat Location: Centered
Oil Hole
vs. Axle
Seat Height 1.65″
With a pushrod seat located .140" deeper than standard location, these Solid Roller Lifters from COMP Cams® are engineered to withstand the demands of aggressive cam lobe designs and increased RPM ranges. They feature a wear resistant tool steel axle and precision sorted needle bearings. Endure-X™ Solid Roller Lifters are heat treated, machined to ultra-high tolerances and fully rebuildable.
  • Patented link bar assembly combines the benefits of a removable link bar with the safety of a captured link bar
  • Needle bearings are precision sorted by size to evenly distribute loads, which prevents premature wear and failure
  • Durable axle is made from wear resistant tool steel to prolong the life of the roller assembly, especially in high RPM applications
Lifters recently inspected and rebuilt by Comp Cams (Not run since).
$250 Takes Them, Half price of new!
Cam not included!
Do you still have how many miles on these do they oil thru push rods
Yes I still Have them. If I had to guess not many miles mostly weekend warrior/fair weather car. Came out of the motor I currently run and were rebuilt by Comp under previous owner. New rollers and bearings, everything else is just a solid chunk of steel so will run like new. Not sure about push rod oiling most Mopars oil thru rocker shaft. They had solid push rods when removed.
M
Whats the best you can do on price and payment and shipping thanks
pm me on lifter
Glad your happy with them.
Regards
