mike mccleery
New Member
Are the caplugs found on the finish painted body areas such as the trunk lid interior, and door jam areas of the door installed before finish paint or after?
Those plugs are installed on the assembly line after the car has been through the paint department. At Chrysler in Windsor, the area that installs the trunk rubber, installs the trunk plugs. The area that puts the carpet in, install the floor plugs. They remove the doors after paint and send them down a different line, so the doors off line will install those plugs.Are the caplugs found on the finish painted body areas such as the trunk lid interior, and door jam areas of the door installed before finish paint or after?
They originals pop up on Ebay.....Glad you touched on the colored door plugs. On the Roadrunner, Sattelite, and GTX there is a small colored plug
on the face of each door. It's a little one with a point on it. Anyone know if anyone makes these?
