How about a preview of the build specs.
What pistons are you using to get that compression ratio? Is there a dish?440 block .030 over
ARP Main studs
440 source 500" stroker crank, rods, and pistons
Edelbrock RPM Performer aluminum 84cc cylinder heads
Cam is 244 @ .050 with a .539" lift on both intake and exhaust. K62 Engle grind.
Harland Sharp roller rockers
Intake is Mopar's copied version of the Edelbrock RPM Performer intake
850 CFM Quick Fuel Mechanical secondary double pump unit.
Should be around 10.75:1 compression and should run pretty healthy. This rotating assembly was already in another super low mileage motor (7,500 mi.) I had that scored the cylinder walls so I have a new block being punched .030" over and align honed and deck checked. I cannot find anything in the pan or anything really crazy wrong with the motor, so I am going to just do it right the way I know how when I reassemble it with the new block. All the machining goodies being done at a local race shop. I figured I would upgrade the rockers and some other pieces while putting it all back together. Should run like a monster with the 4 speed and 3.91 gears!!!
Right out of the gate and seeing the 4 spd W/3.91's, may I suggest filing an Thrust Bearing Oiling feed ? so every time that Clutch tries to push the Crank out the front of the Block it has some Oil there ? And of course depending upon year of the Block, using the late Blocks larger thrust surface Bearings.
Nice tried and proven combo, that with any headwork at all may surprise you.
No dish, just the standard valve fly cuts. The pistons are not the newer ones that they offer. Those are .018 in the hole. These are the older ROSS pistons that are about .027 in the hole. Everything I calc'd with the gasket and all that puts me at 10.75-10.8:1 with 84cc chambered heads. I figure if they clean up the deck surface which is pretty flat and take a few thou off, that'll get me right around that mark.
So your piston to head clearance will be about 0.060 - 0.065" ?
BSB67 you coming up with a different compression idea based off of that? I am all ears for your thoughts.
I’m assuming he recommended that cam due to the CR/intake/gearing choices. That should be a great street driver.My 505 build is:
68 440 block .30 over; been through machine shop where they did the works to it
440 Source 505 with ultralite crank; aluminum mains with ARP studs
Cam from Straub Technologies custom grind: 238 at .05" and .552/.510
Edelbrock RPM Inake (will eventually have Holley Sniper EFI; but haven't purchased yet)
Trick Flow 240 heads with 1.6 Harland Sharp rockers
TTI 1 7/8 ceramic coated headers into 3" exhaust
TF 727 with shift kit going into a 3.23
Yessir, I’m running PB, PS, and A/C so unfortunately I had to leave some on the table as far as cam. But...it’ll still make the 4400 go!I’m assuming he recommended that cam due to the CR/intake/gearing choices. That should be a great street driver.
My 505 build is:
