tx67fury
- 2:04 PM
- Sep 30, 2015
- College Station, Texas
I'd like to hear more on that build too. Very close to what we are doing for Dans '66 Fury.
505 with the 440 source light weight crank, the 27cc dish pistons, zero deck, 0.040" gasket should be right at 10.0:1 compression with the 78cc Trick Flow 240s. 1.6 HS rockers, and Lunati 40230732LK cam. That is a small solid roller, 243/249@0.050", 0.617"/0.624" lift (with 1.6 ratio rockers.) Using stock main caps with ARP studs. Haven't decided on intake, headers, or oil pan yet.
Just dropped block off at machine shop Monday. When we get the block back, we plan to trial fit a few different oil pans and see how they clear the chassis and suspension.
For headers, the best for a c body are TTI...they are pricey but there just aren’t too many others out there with the same quality made specially for C’s. Oil pan will be a challenge, I know a body pans fit, but from what I’ve heard the aftermarket Milodon, etc will have clearance issues; having the stub frame and tie rods down there.
