Need help
7necharger
4:55 PM
Canada
Hi guys need help Just need top floor measurements .
We need more information to help you. Can you be more specific?
I have 70 dodge charger 500 replacing complete trosin bar,front and rear frames and floor.i have the measurement from the bottom but like to check from the top lip to lip
Gotcha. I had a shop weld in my frame rails & all I gave them was the factory frame dimension diagram, so I don't know. There has to be "somebody" on this side with their floor cut out right now who can measure it for you. I think you're smart to double check the top side before you start welding!!!
Thanks yes like to check few Times before I wield.
Please can I have measurement don't care if it's coronet .cuz 67 to 70 b body are all same.
66 work ?
you want just above trany mount and what lower ?
lip to lip is 62"
I want both side lip to lip of rocker panel.from the top and from the bottom. When I removed the floor pan i.didnt put support to hold it so.i think there is a gap between torsion bar.
I cant give you a lower number at this time. car is to low
lip to lip is 62"
Perfect I am getting 62 where is the torsion bar and at rear getting 62 1/4 so I have to pull the back one where the door handle side.
Thanks a lot for the help.if you need any kind of help plz let me know.
I'm 62 1/4 at the rear also
Thanks will do
Ok I thought front and rear should have same measurement like sure box. From Inside should be 56 9/16 .did you replace your frame or floor before?
mine is a 42k mile rust free car. no need to replace a thing
Nice .I just sold my 68 coronet 440 bought from first lady owner rusty free. all original nothing was touched. And from the bottom was like brand new car which I still can't believe when i see other car.did mistake to sell the car.
