- 3:01 PM
- Mar 28, 2014
- South Louisiana
Here's a GREAT instructional video for the Mopar specific SPC UCAs
So...1967coronet440, how do they "stack up" comparatively speaking weight-wise??How heavy are they, look like they weigh a ton.
SPC dbl. adj. UCA's weigh appr. 7# ea. x 2 = 14#'s
Pretty damn good as a matter of fact lolSo...1967coronet440, how do they "stack up" comparatively speaking weight-wise??
According to Budnicks:
BWA-HA-HAAAAA!!Pretty damn good as a matter of fact lol
Ya those numbers were surprising. You can’t tell me those things don’t look like they weigh a ton. Well when I do my uppers SPC just became the top contenderBWA-HA-HAAAAA!!
I already placed the order...
God knows I've researched and pondered and hemmed and hawed long enough, and then there's this thread for good measure!
I'm confident that my appx $1,800 is well spent and will be well worth it!
The price difference between the COMPLETE replacement of my front suspension components going this route vs Gerst (was a top contender) Magnum Force, etc etc, those which would have gotten me rack and pinion steering and I think also changed over to coil overs as well...The PRICE DIFFERENCE AKA the money I saved will pay for the Gerst or RMS triangulated rear suspension system that I absolutely have decided on, so in effect I'm getting a front and rear suspension redux for the price of one of those "other" front suspension kits only.
My suggestion is to get the price from:Well when I do my uppers SPC just became the top contender
I am also a big fan of the QA1 k-member and other components. If I did it, it would be just what you got...without the sway bar...I don't drive mine on the street enuf to worry about that.
Thanks!My car had a bent K-frame when I got it (not horrible but enough to get the driver's front tire out of position) and I also went with QA1 K-frame, sway bar and LCAs, with UCAs from RMS. Hotchkis torsion bars (1.03 I believe) and shocks. I still have the original steering box and I suspect mine has a bit more slop in it than it should, but even still the driving experience has been wonderfully improved.
I think you will be very happy with your upgrade, enjoy!
It would have been worth the full $1,700 to have not had just the one problem that I had at Cruisin the Coast this year. If I wouldn't have caught the front tires making a squealing sound, then noticed they had belts showing (from falling horribly out of alignment when the cam adjuster bolt nut stripped) that could have killed me or wrecked my car.not to say that good front suspension is components are a bad investment
70#'s = maybe 0.070 ET, a lot of the in the 1st 60 ft
is the bag of bolts and washers intact???? When I got mine there was a hole and I'm not sure what all was supposed to be in it...
