383man
You did not run that did you Mike ?? I did not think the areo scoop is legal in any NSS group ? Ron
i think this intake might put u into the 8's.......sometimes we have to get creative..right...............
wow awesome performance. going back in time to mid 70's a California racer- Dick Boyington(sp) ran a '68 Charger with 440, torqueflite, I dont know the gears. it had frame tied on one side only, roll bar and really no attempt to lighten.his claim to fame was the tarantula manifold with a 5/8" spacer under the carb. the car ran consistent 10.30/s at over 130. the Rettig Bros would have details about dicks care I'd think. dick is no longer with us.You did not run that did you Mike ?? I did not think the areo scoop is legal in any NSS group ? Ron
1".Do you know how much taller it is then the Indy crossram ? Ron
Ron, No, the Harwood Aero scoop is not ok with the AFX / Nostalgia Group here in California. That is the reason I had to spend a buncha bucks on a new 5" Hemi Style Scoop.You did not run that did you Mike ?? I did not think the areo scoop is legal in any NSS group ? Ron
View attachment 679417 buttoned up and almost ready to fire,,3 fuel lines left to fab and relocate the coil,,,holley tuning time..mainly the power valves..and double pumps..View attachment 679392 View attachment 679393
i have heard original race hemi holleys run rich and was told to stay away from them unless racing,,,but i'm going to start with the power valves,,no throttle,in gear, brake applied, measure vacuum,,need a valve half the measured vacuum to avoid a rich condition..if its 5",,need a 2.5 power valve,,then on to the accelerator pumps, shooters, and last but not least jets after a trip down the road,,,these r 600 cfm double pumpers..maybe you can school me on Holleys. I had teh correct,new original Hollys on the hemi cross ram, it ran awesome on the street- but with a sudden misstep while driving it sounded like it was missing, plugs/coil/ignition OK, from then on when I'd try t o accelerate it was very sluggish, disappointing for a hemi. never found the reason, power valves perhaps? its why I stay with carters, they do not perform like holley but also not as cantankerous.
AGAIN:fabbed air cleaners today after more work on the scoop...k&n extreme air tops on air bells...appx 1/8" clearance to scoop.
X2!I like it!
The air bells are they quick fuels 10 5/8"? K&N 66-1101 filter tops with od trimmed down? Nice setup.fabbed air cleaners today after more work on the scoop...k&n extreme air tops on air bells...appx 1/8" clearance to scoop..should work as well as the foam fly eye cleaners found on the baldwin/motion cars with out flaming out upon any carb backfire..View attachment 683284 View attachment 683285 View attachment 683286
yes...trimmed down 3/8" on the bottoms and 1 1/2" on the sides to match the extreme 11" trimmed down tops...aviation tin snips made quick work of them...with the larger tops,its all air cleaner element for flow...9" tops would have bolted on but with alot less filter.The air bells are they quick fuels 10 5/8"? K&N 66-1101 filter tops with od trimmed down? Nice setup.
only 1 thats close is the front at foreword most passenger side leading edge,motor is factory tilted in car,,,appx 1/8" clearance,,with the motor plate,thats enough,but theres still more i could cut off the bell's before the filter would touch the carb,,How far are the filters from the bottom of the scoop?
