Dibbons
- 6:41 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I have squeal when turning my '72 Satellite Sebring Plus. It tracks straight when I let go (briefly!) of the steering wheel. I found an alignment shop (no computer) down the street. I have measured toe in twice and camber once now at home. It will be interesting to see how close my data comes to the shop data. For the record:
First attempt measuring alignment at home
12/3/2018 1972 Satellite Sebring Plus
Passenger tire toe in with rope method against rear tires
1 1/2” minus 1 1/4” = 1/4”
Driver tire toe in
1 4/16” minus 1 3/16” = 1/16”
total toe in 1/4” + 1/16” = 5/16”
Second attempt measuring alignment at home
12/7/2018 1972 Satellite Sebring Plus
Passenger tire toe in with even rope method (76 3/4” equidistant spacing front/rear)
5 3/8” minus 5 1/8” = 2/8” = 1/4”
Driver tire toe
5 5/8” minus 5 3/8” = 2/8” = 1/4”
total toe in 1/4” + 1/4” = 1/2”
rope to center hub cap distance:
RF 3.5”
RR 4.5”
LF 3.5”
LR 4.5”
1972 Plymouth FSM Page 2-20:
front track 59.6 with 10” brakes
front track 60.2 with 11" brakes
front track with disk brakes (mine) not listed
rear track 62.0” with 8 3/4 rear end
rear track 61.6 with 7 1/4 rear end
FSM specs for rear track with 8 1/4 rear end (mine) not listed
toe-out on turns 20 degrees inner/17.8 degrees outer
steering axis inclination 7 1/2 degrees
Camber measurements at home using 24” carpenter square, bubble level, tape:
Passenger tire
1 18/32” minus 1 12/32” = 6/32 = 3/16” = .69 to .75 negative degrees camber
Driver tire
1 18/32” minus 1 17/32” = 1/32” = .12 to .125 negative degrees camber
Just for fun “rear tire toe”:
Passenger tire (RR) 4 9/32” minus 4 10/32” = 1/32” toe out
Driver tire (LR) 4 9/32” minus 4 7/32” = 1/16” toe in
Tire temperature after 15 minute drive (I would expect these temps to lower and even out once alignment is corrected):
LF 136 outside tread
LF 101 inside tread
RF 136 outside tread
RF 113 inside tread
LR 98 outside tread
LR 98 inside tread
RR 113 outside tread
RR 104 inside tread
Driver tire toe in
Driver tire toe
RF 3.5”
RR 4.5”
LF 3.5”
LR 4.5”
Passenger tire
Driver tire
LF 101 inside tread
RF 113 inside tread
LR 98 outside tread
LR 98 inside tread
RR 104 inside tread
