WTB 440 pistons
Garys1969RR
3:47 PM
Colorado
Feedback: 2 / 0 / 0
Looking for a set of 440 pistons with a 2.067 C Height. The L 2355 F is 2.061, would be OK. Or a 440 6 pack piston should work too. Anyone have any?
I have this set of stock pistons and rods out of a 68-69 440.
I will split off the pistons for $100.00.
I've got some 2295s but the domes have been whacked off, you wouldn't want them. I was asking for info for others who might be able to help.
If none of the above don't work for you I got a set of "L" 440 rods I bought new, only have about 500 miles maximum. PM me if you are interested.
Well the ICON piston has a 2.067 C Height. And it's a flat top. So may go that route, unless I decide to build a 451.
Great. Like to get them a new home.
Merry Christmas.
Bear in mind that 440 pistons prior to 1968 had a lower compression height due to the closed combustion chamber heads. After 1967 the heads all had open chambers and the pistons had a taller compression height. Use later pistons with early heads or vice-versa to up your compression ratio by about 1 point.
Yea, that makes sense
Trying to get some quench, so the
.050 deck clearance found in the 68 69 440 s, wouldn't be enough to get quench
I've got speed pro 2295s.;(domes)030 over .I'm at 52537 $160shipped
You know, Moparguy, I may be int in those pistons. Can you text me a few pics of one of them? Mainly the sides and tops. How many miles are on them? Thanks. 720 496 3146. Gary
